[RESOLVED] System/Wheel Animated gifs in 4.15 (not animated ?)
Hey @Tom Speirs
I downloaded today the new version of PBX that supports animated gifs. Nice feature  ! And unexpected after releasing 4.14 this week
I created as example a small animated system GIF for FX :
But when running PBX, I only see a still image for the system (on the system screen, but also as preview per table)
Is this only for wheel images ? Or do I miss something ?
Edit : Tested also a animated gif as wheel, but that's not working for me too. just a still image
It should be working. Not sure why. Can you post a log? Maybe its an issue with that particular file I expect. I did put a limitation on number of frames. I will look.
Yeah that GIF is 215 frames. Its too big. I put a limit of 70 frames so it does not use up too many resources. All the frames need to be loaded into direct3d surfaces so there is a limit.
Wow. You worked all night on this.
Just woke up. Need to create breakfast for mrs mike da spike. I will check after. Thanks Tom!
I appreciate all your work
Working like a charm.
Don't see any delay or something on my cab or on my test device (PC not a laptop)
Thanks Tom !
