Please locate and attach copies of your gameex.ini and log.txt files for review.
Hi,
Please contact me directly regarding your purchase. Otherwise, I think you may have found a bug (which I can likely fix).
It looks like your in an unusual view mode which may be causing a problem.
If you not invested time setting things up please uninstall GameEx, delete the folder then install again.
So I try setting it up. I don't even know what I'm doing. Its not as simple as retroarch and Steam Big Picture mode. I was looking for something like Big Picture Mode just with more customization. I'm still experiencing freezes every time I exit a menu for 11min.
log.txt GameEx.ini
Your log looks very strange. Not sure what is going on. Looks like your running two versions at the same time or there is an issue with your display adapter.
What exactly did you configure or do? Did you delete the folder after uninstalling?
Like I said, if your not happy you can contact me.
Sorry this did not work out for you.
You may click on his name in his last post and click the "envelope" icon that shows in his profile to send a private message.
