Hi there. I got trouble with Citra 3ds Emu. Won't work in fullscreen mode. Somebody knows the whole command line in setup wizard for Citra to open fullscreen mode?
I am assuming you have searched elsewhere for command line switches and came up empty. If so, then I have probably replicated your search results.
Nothing for a command line switch so far. I have come across:
A custom layout set within Citra for fullscreen top/small screen bottom or small screen top/fullscreen bottom.
More custom layouts with one just for fullscreen.
Everything else points to possibly using an AHK (Auto Hot Key) script to launch before the game to simulate pressing F11.
Command line switches are as follows:
Usage: citra.exe [options] <filename>
-g, --gdbport=NUMBER Enable gdb stub on port NUMBER
-i, --install=FILE    Installs a specified CIA file
-m, --multiplayer=nick:password@address:port Nickname, password, address and port for multiplayer
-r, --movie-record=[file]  Record a movie (game inputs) to the given file
-p, --movie-play=[file]    Playback the movie (game inputs) from the given file
-d, --dump-video=[file]    Dumps audio and video to the given video file
-f, --fullscreen     Start in fullscreen mode
-h, --help           Display this help and exit
-v, --version        Output version information and exit
  • Thanks 1
