Hi all newbie here.  I setup Gamex and all the mame 0.209 directories within Game ex and I am getting this error "HRESULT: [0x8876086C], Module: [Unknown], ApiCode: [Unknown/Unknown], Message: Unknown".
Any help in figuring out what is wrong will be appreciated. Here is the gameex log file:
11:10:38.45  1/20/2020:  Opening Configuration File
11:10:42.52  1/20/2020:  GameEx Arcade Edition x64: Version 16.04: Starting Log
11:10:47.23  1/20/2020:  Windows 7 Home Premium Service Pack 1 64-bit
11:10:47.25  1/20/2020:  Aero running
11:10:47.30  1/20/2020:  Initializing Vista/Windows 7 volume control
11:10:47.59  1/20/2020:  Getting CPU and RAM info
11:10:48.14  1/20/2020:  Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz, 4015MB
11:10:48.40  1/20/2020:  2.19Ghz - 2 Cores or CPU's
11:10:48.40  1/20/2020:  Running Randomize()
11:10:50.14  1/20/2020:  Loading PlugIns
11:10:50.74  1/20/2020:  Checking for applications to Launch On Startup
11:10:50.74  1/20/2020:  Setting default net connection limit to 25
11:10:50.88  1/20/2020:  Running Misc startup tasks
11:10:50.88  1/20/2020:  Setting Menu types
11:10:50.92  1/20/2020:  Getting Configuration Values
11:10:50.93  1/20/2020:  Using Theme: Default - Default
11:10:50.93  1/20/2020:  Checking for alternate Image Directory for Theme: Default - Default
11:10:50.93  1/20/2020:  Launching HideOS.exe
11:10:50.93  1/20/2020:  Initialising Video/MNG DLL's
11:10:50.93  1/20/2020:  CPWizard enabled
11:10:50.93  1/20/2020:  GameEx will check for media insertion (may affect performance)
11:10:50.93  1/20/2020:  Hiding Taskbar
11:10:51.10  1/20/2020:  Is Media Center running?
11:10:51.10  1/20/2020:  Checking/Creating LCD Registry values
11:10:51.30  1/20/2020:  Check Media Center Exit/Start Mode
11:10:51.30  1/20/2020:  Media Center Mode 2
11:10:51.38  1/20/2020:  Video previews on. Warning: Only recommended on modern systems
11:10:51.38  1/20/2020:  Snap Delay set to: 5
11:10:51.38  1/20/2020:  Get other settings
11:10:51.40  1/20/2020:  Set: Find emulator artwork on best match basis
11:10:51.40  1/20/2020:  Start work for Form
11:10:51.40  1/20/2020:  Getting Original Screen Size
11:10:51.62  1/20/2020:  Opening Database Connection
11:10:51.62  1/20/2020:  Data Source=E:\GameEx Arcade Edition\DATA\data.db3;Pooling=true;FailIfMissing=true
11:11:15.30  1/20/2020:  Initializing Component
11:11:16.17  1/20/2020:  MAME Path is: E:\mame .209
11:11:16.17  1/20/2020:  MAME EXE file is: mame64.exe
11:11:16.17  1/20/2020:  ROM Path is: E:\mame .209\roms
11:11:16.17  1/20/2020:  Catver.ini is located at: E:\GameEx Arcade Edition\DATA\catver.ini
11:11:16.17  1/20/2020:  controls.ini is located at: E:\GameEx Arcade Edition\DATA\controls.ini
11:11:16.61  1/20/2020:  History.dat is located at: E:\GameEx Arcade Edition\DATA\history.dat
11:11:16.61  1/20/2020:  nplayers.ini is located at: E:\GameEx Arcade Edition\DATA\nplayers.ini
11:11:16.61  1/20/2020:  command.dat is located at: E:\GameEx Arcade Edition\DATA\command.dat
11:11:16.62  1/20/2020:  MAMEinfo.dat is located at: E:\GameEx Arcade Edition\DATA\mameinfo.dat
11:11:16.62  1/20/2020:  Loading Controls.ini map file
11:11:16.87  1/20/2020:  Snap Path is: E:\mame .209\snap
11:11:16.87  1/20/2020:  Database Snap Path: Not Found
11:11:16.87  1/20/2020:  Background Snap Path: Not Found
11:11:16.87  1/20/2020:  AVI Snap Path: Not Found
11:11:16.87  1/20/2020:  Video theme Path: Not Found
11:11:16.87  1/20/2020:  Video background Path: Not Found
11:11:16.87  1/20/2020:  Flyer Path is: E:\mame .209\flyers
11:11:16.87  1/20/2020:  Cabinet Path is: E:\mame .209\cabinets
11:11:16.87  1/20/2020:  Cabinet 3D Path: Not Found
11:11:16.87  1/20/2020:  Title Path is: E:\mame .209\titles
11:11:16.89  1/20/2020:  Title Path is: E:\mame .209\logo
11:11:16.89  1/20/2020:  PCB Path: Not Found
11:11:16.89  1/20/2020:  Artwork Preview Path: Not Found
11:11:16.89  1/20/2020:  Panel Path: Not Found
11:11:16.89  1/20/2020:  Manual Path is: E:\mame .209\manuals
11:11:16.89  1/20/2020:  Icon Path is: E:\mame .209\icons
11:11:16.89  1/20/2020:  Marquee Path is: E:\mame .209\marquees
11:11:16.94  1/20/2020:  Applying Language/Text
11:11:16.94  1/20/2020:  Text/Language: English
11:11:16.00  1/20/2020:  Loading Language/Text
11:11:17.01  1/20/2020:  Loading Addins
11:11:17.25  1/20/2020:  Using Version 3 Themes Animations
11:11:17.25  1/20/2020:  Retrieving resolution setting
11:11:17.44  1/20/2020:  Using General Font: HandelGothic BT
11:11:17.44  1/20/2020:  Using Title Font: HandelGothic BT
11:11:17.51  1/20/2020:  GameEx will try to reduce CPU usage
11:11:22.99  1/20/2020:  Initialising Direct3D
11:11:23.77  1/20/2020:  Applying GameEx is Loading Image
11:11:24.00  1/20/2020:  Setting Resolution to 1280x1024 32 bit color
11:11:24.20  1/20/2020:  Creating Surfaces
11:11:24.22  1/20/2020:  Creating device - exclusive
11:11:26.58  1/20/2020:  Warning: Display is running in full screen compatibility mode.
11:11:26.69  1/20/2020:  Applying GameEx is Loading Image
11:11:26.70  1/20/2020:  Setting Resolution to 1280x1024 32 bit color
11:11:26.70  1/20/2020:  Creating Surfaces
11:11:26.70  1/20/2020:  Creating device - windowed
11:11:26.72  1/20/2020:  --**--
11:11:26.72  1/20/2020:  Error: HRESULT: [0x8876086C], Module: [Unknown], ApiCode: [Unknown/Unknown], Message: Unknown
11:11:27.82  1/20/2020:     at SharpDX.Result.CheckError()
11:11:27.82  1/20/2020:     at SharpDX.Direct3D9.Direct3D.a(Int32 A_0, DeviceType A_1, IntPtr A_2, CreateFlags A_3, PresentParameters[] A_4, Device A_5)
11:11:27.82  1/20/2020:     at Direct2d.Device.NewDevice(Form FormHandle, Int32 Width, Int32 Height, Boolean Windowed, Boolean VSync, Boolean Display16Bit, Int32 DisplayNbr, Int32 RefreshRate, Direct3D _Direct3d)
11:11:27.82  1/20/2020:     at Direct2d.Device..ctor(Form FormHandle, Int32 Width, Int32 Height, Boolean Windowed, Boolean VSync, Boolean Display16Bit, Boolean SecondaryDisplay)
11:11:27.84  1/20/2020:     at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8, Boolean A_9)
11:11:27.84  1/20/2020:     at GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
11:11:27.84  1/20/2020:     at GameEx.GameEx.MainForm.InitDirectDraw(Boolean nodispose, Boolean reinit, Boolean DontLoadSurfaces)
11:11:27.84  1/20/2020:     at GameEx.GameEx.MainForm.a(Boolean A_0, String A_1, Boolean A_2)
11:11:27.84  1/20/2020:     at GameEx.GameEx.MainForm..ctor()
11:11:27.84  1/20/2020:  Closing database connection
11:11:27.87  1/20/2020:  Disposing Plugins
11:11:27.87  1/20/2020:  GameEx is exiting with errors
11:11:27.87  1/20/2020:  Deleting search cache
11:11:29.28  1/20/2020:  ERRORS DETECTED: EXITING
11:11:39.57  1/20/2020:  Bye
On 1/20/2020 at 3:52 PM, utena10jou said:
Thanks, will check my drivers and go from there.
@Tom, checked all my drivers and everything is okay. I am running mame 0.209 on older hardware. It is a limitation of my on board video. I did install an older version of Gamex which launches but hangs up while reading the listinfo.dat. Still stuck.
2 GB if RAM is a recommended minimum for Windows 7 64 bit per Microsoft. In my experience, 4 GB is fine for moderate use, but with an add-on GPU as it allows video to use the GPU RAM and less of the shared RAM on the motherboard.
Adding more RAM to your system may alleviate the issues using the integrated GPU, however, I've seen better results leveraging an add-on GPU with a few GB of video RAM.
Im not sure why it wouldn't work. What old version works for you?
Using version 10.18. I did leave it running for half and hour and it was still stuck at 25%.
I am using an older hp desktop that I was going to toss which I turned into my mame bartop. It uses ddr2 memory so its pretty old intel chip and mb. As I have a new laptop. Call me cheap :) but I don't feel like investing in an old system. I did consider buying a video card to install but decided against it. I would have to get a pcie gen 1 video graphics card!!. Prehaps I may find them used cheap but decided not to spend the additional time on it.
Understood. There comes a point of diminished returns trying to search for more obsolete kit to keep the rest of the obsolete kit running. Got the t-shirt for that one.
Just out of curiousity, have you tried installing the latest 32-bit version over the top of your current installation? I searched and came across this page https://softwareengineering.stackexchange.com/questions/315810/is-there-a-good-reason-to-run-32-bit-software-instead-of-64-bit-on-64-bit-machin
Benefits of 32-bit software in 64-bit environments
Lower memory footprint, especially in pointer-heavy applications, 64-bit vs 32-bit can easily double the memory requirements.
Object files are smaller as well.
Compatibility with 32-bit environments.
Memory leaks are hard capped to 2 GB, 3 GB, or 4 GB and won't swamp the entire system.
It may be worth the try. No additional cost anyways other than time.
