Hi
I have updated to 4.06 and i am using the use pinmame in frontend setting on a pin2dmd. The static images are showing on the pin2dmd but pinmame is not showing. If i go back to 3.75 it works no problem. I can't find any difference in the settings of both versions can you have a look when you have time please.
Cheers
log.txt PinballX.ini
  • 5 months later...
Hello Tom,
see this thread for ref:
Have you had time to look at this yet?  Not sure if this is really a PX version issue or not.
Thanks.
