Help - my Configuration App is Haunted!
Hi people,
just wondering if anyone elses Configuration App is acting strangely?
I added some more emulators today, & thought i'd re-shuffle them into a better order, plus delete some ones i dont use any more.
The thing is that I cant completely delete them, (disabling isnt the problem), im trying to get the unused emulator spaces to appear as 'Emulator #' but the old emulator name still remains next to it.
Ive tried editing the GameEx.ini to remove the unwanted emulators, but they still appear in the config app...spooky :ph34r:
Any ideas?
Alan
Hi people,
Any ideas?
Alan
Call Ghostbusters! .....or Tom. :D
i would use my trusty notepad
though that doesn't really solve the problem, if i want to edit more than a few things i think that's much faster. just back it up first and/or don't make mistakes.
Thanks guys :)
Its not really a problem unless others have noticed it too.
Your right though Smiff, i ended up using notepad it was the only sure way to make changes...i was getting confused when the ghosts started messing with me :blink:
Thanks guys :)
if your talking about it saying the old emulator name in the configuration, i think it's normal, because that's happened to me. adding another emulator usually changes the name after you re-open config, but even if not, it's nothing noticable from inside gameex, so i wouldn't think it mattered.
