Is the alternate exe option working?
I am trying to use but without working. When I add a new table this alternative is deleted  for my all vp9 tables
I have VPX as a separate system so don't use alternate exe, but i can probably rig up a test
Please attach your pinballx.ini, log.txt (after launching a VP9 table) and your visual pinball xml.
ITs working on my system but to be honest havent updated for a few weeks so maybe are you using a newer version if your error is via PBX.
Yes I'm got the newest version of PBX.  Everything was working normally before. PBX works well with VPX. The alternate exe command is calling VPinball995 in the same directory as vpx.
OK I replace <alternateexe>VPinball995</alternateexe> to <alternateexe>VPinball995.exe</alternateexe> and works like a charm. The problem now is why I work with the game manager it deletes alternate exe?
Sorry, bit slow testing, but yeah i get the same issue with game manager in v4.06 - edit a database in game manager and on save removes the alternateexe flag from the xml.
What version did you update from where it was working ok?, will probably help @Tom Speirs track it down
