I am using a "lite" version of windows. (I own a legit copy of Win7)
because a full install requires almost 30 gigs
and I have the whole system running off a 64 gig ssd
Easy to backup and cheap to replace.
So it might be something you implemented along the line that uses dlls I'm missing?
Wouldn't it throw an error or something?
Generally speaking, we have discouraged using "lite" versions of Windows OS's over the years for this very reason of it generating one off errors that nobody else encounters due to library dependencies that are specific to the frontend.
Tom may be able to fix this issue, but no guarantees that others may not crop up over time as the program evolves.
Well I have installed Pinballx 14 times and the winner is version 3.43
I should have gone older to newer. lol
Tom, I tried switching 4.01 and 3.42 bass.dll files. Problem still there. :unsure:
I understand that using Windows "lite" is probably the problem.
I think I'll just have to go without the video loading.
I was just hoping it was something simple.
Yes you did. Everything is working.
Auto mute during attract mode is working and Table audio glitch is gone
And everything else new as well.
Thanks again for the best support I've ever received.
