Video recording using game manager no longer working starting with v3.77
Updated post to include log and config file. For the purpose of this example, I just tried to record one DMD video. If I revert back to version 3.76 without changing any settings, it starts working again.
13 minutes ago, Tom Speirs said:
Hi, well your a few versions behind there. So please do the same with current version.
Uploaded 2 logfiles. One for working 3.76 and one for non-working latest 3.93.
13 hours ago, Tom Speirs said:
Please try the replacement pinballx.exe and let me know the results.
Thanks.
Tom
Thank you. The video capture appeared to have worked this time using the replacement exe. However, they are not playing inside of PinballX. They play fine in VLC. I also have the LAV codecs installed. Is there a recommended set of codecs to install?
8 minutes ago, scutters said:
Post a screenshot of your LAV settings. Are they like in this post?
Thank you! I had mine on the default settings. Copying the LAV settings from that post fixed the playback issue.
Tom, I may have spoken too soon. If there are multiple tables queued up for recording, only the first one is captured properly. It attempts to launch the succeeding tables but only stays on for a couple of seconds and nothing gets recorded. Log attached.
log-3.94.txt
