being new, my problem is when I close some emulators, eg project64 or gen +, with a key on the joystick assigned to a macro keyboard alt + f4, gameex arcade back but it remains locked, joystik and button does not work I can only press esc key on keyboard.
Do you have any suggestions?
thank you
Probably need for you to attach copies of your gameex.ini and log.txt files for review (NO copy and paste please).
Thanks.
I saw only now that there is a native output configuration, try it tonight.
I would say to close ...
update:
ok antimicro not work i try with joytokey and work.
it would seem to work now I do tests
hi
strange thing if I use the keyboard for alt + f4, everything works (project64), gameex responds, if I use antimicro to assign to a button alt + f4, gameex returning is blocked.
Do you have any indication to close the emulator?
thz for support
log.txt GameEx.ini
