hello guys, i'm having problems with pinball fx3. it works fine if i start it like usual, but launching it inside pinball x it exits after 15-20 seconds. any help?
thanks in advance
here's my files:
edited
forgot to tell you that i'm using last pinballx version and i've installed 32bit after having no luck with 64bit. vpx tables works flawlessly
log.txt PinballX.ini
Do you have PBX running as admin ?
I have exactly the same setup (only have the paid steam version of zen pinball fx3) and working like a charm.
  • Draco1962 changed the title to [RESOLVED] pinball fx3 shuts down after few seconds
