Problems with mattel intellivision (Nostalgia)
Hi all!! I have installed last week the emulator for matel intellivision games (Nostalgia) and I configured it with the configuration includeid in gameex configuration, but I seen a black screen (when i launch any game) and then return to gameex.
What is my problem?
I have nostalgia perfectly installed, because i can launch any game with the emulator (without gameex).
Thanks in advance!!!
Usually when this happens it is returning you to GameEx because there was nothing to do. For example you somehow don't get the path and filename correct in the GameEx setup, so the filename passed to your emulator isn't valid. Therefore the emulator starts, sees nothing to do (or nothing valid) and craps out. Check your file paths, etc. Then try to run the emu from the command line. Then turn on "debug" mode for that emu so you can see the filename being passed in. If all this is fine, then you are probably passing it a bad command line option or something.
