Hi All,
Been using GameEx Arcade edition for a couple years and love it. I recently reconfigured my OS and had to re-map my controllers. For some reason I can't get any joysticks other than joystick 1 to save in any of the input settings. When I tap say Joycode2_button5, it is recorded in the setup wizard UI, but when I save and reload the setup wizard, joycode1_button5 is displayed. The custominput.ini file shows simply "4" as the value for this field - there is nothing indicating it is joystick 2.
Any ideas? This worked for me before I had to remap my controllers.
Can you attach copies of your gameex.ini and log.txt files (no copy & paste, please) so they can be reviewed?
Also, you may want to note what joysticks or interfaces you are using.
Thanks!
