First Sorry My poor english.. ill try without google translate.
I'm having a problem with Pinballx and the shutdown.
When I put it off from the option it leaves my pc in a close session.
Does anyone know where I can change the Pinballx code for a direct shutdown option? as "shutdown / f / s / t 0"
Please if someone had or has this problem, do you notify me?
Thank you!!!!!
Not sure if your problem is a pbx issue or a Windows issue.
What OS do you run ?
Found this on internet. Maybe helps you
  1. Go to Control Panel
  2. Power options
  3. Choose what the power buttons do
  4. Change settings that are currently unavailable
  5. UNCHECK Turn on Fast Startup (recommended)
If not, please post log and ini file (as files not copy/paste as text)
