Ok, so I'm finally sitting down to get PBX up and running on my new(ish) pc, grabbed the .xml someone was nice enough to share for PBFX3, and I'm having an issue launching any tables. The only ones I want are the PBFX3 Williams/Bally tables with the upgraded physics, and what happens when I launch them is the "loading" screen covers my playfield, the backglass loads properly, and I hear the PBFX3 music start, then it loads the table and I hear the table music. I can even launch the ball. If I Alt+TAB through my windows, I can see the playfield screen from PBFX3, but if I try to select it, nothing happens. The loading screen still covers my playfield monitor. Someone said a while back in an old thread that you have to add -class to your PBFX3 system setup in the PBX settings to launch the realistic physics mode, which I did. I think I attached the correct relevant files. Thanks in advance for any help!
PinballX.iniFetching info... Pinball FX3.xmlFetching info... log.txtFetching info...
You got the right files!
Try updating pinballx to the latest version, 3.38 (you're on 3.02) - and install the 32 bit version. Please also confirm if pinballx and/or fx3 are set to run as administrator (right click on the exe files, Properties->Compatibility)
And then post the files back again..
  • Draco1962 changed the title to [RESOLVED] PBX Stuck on Loading Screen
  • Draco1962 locked this topic
