When I have the Executable File set to open VpinballX.exe it will only open a vpx file. All the vpt files open with the playing field at 200% and the game doesn't load. When I have the Exe set to open Vpinball955.exe it will open all my vpt files, but won't open the vpx file. Why won't the VpinballX.exe open my vpt files correctly through your system? Is there something I could have missed in the set up?
You have two main options, either add a custom system in settings.exe for diferent VP versions or use the alternateexe flag in the database xml file to point at the correct exe.
Have a look at this thread. Let us know if you need more help..
