I am building an arcade cabinet that will be completely offline. I was going to register GameEx Arcade to get rid of the nag screen and get the extra features, but I see that registration is only for one year. Will the nag screen come back and extra features be disabled after the year or will I just loose access to the extra online features? Like I said, once I am done building this it will never be online again.
There should be 2 registration options - 1 year and Lifetime.
If you choose the latter, then you should be good.
2 hours ago, DrJekell said:
So you are saying that if I choose the 1 year, the nag screen will return?
If you choose to upgrade, yes, if not, no.
So to answer your question, the answer is no, it will not return. However if you choose to tinker with things and need to upgrade for any reason and use a newer version then yes.
