Hello,
thanks for all the updates and the hard work on it.
The issue I brought up before as I saw in 3.28 is still there....any chance to have a look?
Thank you!
Here you are although same sitiation as before in prev post.
This is what I did for the test:
- started PBX, browsed to Atlantis (so far so good, all dmd screen change with tables, both static ones and displaymovies)  then I start Atlantis, in the game manager is set that the display stays on (not hidden).
Play Atlantis, Exit Atlantis and browsing again through tables will not change the dmd anymore.|
When starting a real dmd-table (like I did with Austin Powers) when the table is initializing the correct Austin Powers display comes up so, as far as my knowledge goes, there is no problem in communication or hang-up.
Thank you for your support!
[SETTINGS].logFetching info... log.txtFetching info...
PinballX.iniFetching info...
Some logging options may have changed between versions, so as a general rule, you should attach latest copies of the files whenever you have changed versions.
