Hi I have game ex on a cocktail cabinet. We had a power cut mid game yesterday and now it will not load up I get the following message
GameEx: version 5.31: starting log
Operating  system platform: Win32NT
Operating system name: Unknown
Operating system version 6.1.7601
ERROR: An error occurred while checking the previous instance of Game Ex
This is caused by a bad windows or .net install
GameEx will likely function incorrectly as it cannot check for running processes
Applicstion-defined or object define errors
ERRORS DETECTED : EXITING
Hi Marc - I just saw this post in the Convert-It support forum.
Can you attach (no copy & paste, please) copies of your log.txt and gameex.ini files?
Based upon the error message, you have quite an old version of GameEx installed (5.31 vs. current 15.53) so we may be limited in the assistance we can provide. We understand that your hardware may not handle an OS upgrade due to lack of drivers, etc. The support files may help us guide you.
You may need to reinstall the .NET Framework for your OS before continuing, however, making a backup of your GameEx installation and assets (ROMS, media, emulators) is likely paramount as you could easily have to reinstall the OS.
