Try installing the 32 bit of version of pinballx (don't select the 64bit option during the install wizard)
From log;
05:36:09.8  3/14/2019:  PinballX - Version 3.30 x64
Could you please try the previous version of PinballX (download from this site). 3.30 was a pretty big update and I need to ensure I didn't break anything.
Please report back.
Please report back.
@Tom Speirs all working fine for me now on version 3.30
Please report back.
I'm on 3.30 now.  Where is this previous version?  3.30 is the only option for download.
Having crash problem with FX3 as well.      FX3 gets to the point right before you start playing and then just exits and end back at PBX menu.     Installed 3.30 32bit with no other changes.
No issues when I was running 3.29
PinballX.ini
PinballX.iniFetching info...
log.txtFetching info...
Please try 3.29 again. The person who started this topic just said the previous version has the same problem. Maybe steam did an update. It was reported in another topic that the exe process name may have changed. Im not able to test right now though.
Please report back.
If it helps I just tried the Pinballlite.exe on 3.30 and 3.29, and FX3 works fine there.
