I was having a problem with the dmd being behind the backglass on a couple machine and seen on a post CENSOREED had a program to run which I did and now my backglass shows until the dmd loads then it goes black the program was VpmToFront and im using pinpall x I have attached the files
thx
VpmToFront.exe
VpmToFront.ahk
Have you reached out to Censored about his .ahk script for assistance?
Also, you failed to attach copies of your pinballx.ini and log.txt files or mention what emulator and tables are having the problem.
That's ok. The requested files can be found within the config and lof folders.
