I would very much like to run Gameex AE in WINDOWED mode, on my Pincab.
I have a pair of monitors in the backbox of my Pincab, that sit side by side to create a very large picture area. And I want to rune AE in windowed mode si I can span monitors 2 and 3.
I have the dual monitor mode setting tunred on in the settings. But his causes AE to go full-screen on monitor 3. This leaves monitor two blank.
So if I can simply run AE in windowed mode, and I can select the size of the window to span monitors 2 and 3, I may be good to go.
Not sure this can be done natively. You may need to explore other options such as Display Fusion or, if someone is aware of a free app with similar functionality.
Enhancement request perhaps...
Thanks draco. Obviously i am looking for the best system for my three monitor pincab.
Is there a way to force ae to appear on monitor 2, rather than monitor 3 as it is now? Mame appears on the large monitor 1 in the lower cab. If i can force ae to monitor two maybe in the ini, that would be desirable.
Check under the Display Settings via the Setup Wizard. In that area for legacy GameEx, there are settings for Fullscreen Windowed and Display on Second Monitor.
