Don't know if this should be a feature requirment or a theme requirment hence why i'm asking! Is it possible to filter games by first letter though, at the moment to get to S i have to go through all games A-S where as it'd be really nice to just select S!
There's a really nifty feature called "Alpha paging". To use it, first make sure that you have your shift button mapped, then go to GameEx Configuration app->Input and enable alpha paging.
Return to GameEx and position yourself in the game list, press and hold your shift button and turn your joystick right to skip from A->B->C->D->Etc. Hold shift and turn your stick downwards to skip a page.
Emph
Hmm, i'm using an xarcade stick.....can't remember if that uses shift or not now.
No, I meant which button you have set GameEx to accept as your shift key. But I guess that Tom is right. I am also using an X-Arcade, but I have reconfigured my buttons so I don't know the exact layout.
Emph
