I googled for 2 hours now a found now solution. I can not start FX3 tables directly or import the tables in the Game Manager of Pinball X.
I copied a FX3 XML file but when i launch the Game Manager and klick on Launch it says table not found. In Pinball X itself it starts the game not the selected table.
Cabinet Mode Activation Code is enabled in FX3. I don't have FX2 enabled, guess that is not the problem.
Hope anybody can help. .pxp tables are there in C:\Program Files (x86)\Steam\steamapps\common\Pinball FX3\data\steam
Pinball FX3.xml
PinballX.ini
8 hours ago, Outhere said:
FX3 Games will not launch from Game Manager
OK, do you had anything to change in the settings to launch a table directly from Pinball X?
It launches the game only on my pc. do you have to play a tutorial first in FX3 or unlock something?
Should be ok no?
[PinballFX3]
Executable=steam.exe
Parameters=-applaunch 442120 "-table_[TABLEFILE]"
Process=Pinball FX3.exe
Rotate=True
WaitFor=20
LaunchBeforeEnabled=False
LaunchBeforeWorkingPath=
2 hours ago, GAH1068 said:
Do you have a cabinet unlock key from Zen?   You need it to launch table from PBX now from what I have read.
Sure, cabinet key is activated.  i did a complete re-install of pinball x and fx3 no luck. the game is starting but never the table directly as shown in several youtube videos.
