GAH1068 Posted October 20, 2018 Author Share Posted October 20, 2018 I'll upload my FCM settings Ini, can't think of anything else that would cause problem. Not a script or PBX if that doesn't work from there Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 20, 2018 Author Share Posted October 20, 2018 @hawkeyez88 Attached is my FCM settings.ini. Update the file for your monitor config and see what happens. If you can't launch a table outside of PBX then it has to be something with your settings with FCM, permissions or something to that effect. You might have to ask NoEx in his post on DigitalPinballFans.com and see what he thinks. It has always worked for me once configured right so I am at a loss what else to try. Settings.ini Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted October 23, 2018 Share Posted October 23, 2018 I ended up resetting my controls inside of pinball arcade and things work!!!!! Thanks GAH! 1 Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 23, 2018 Author Share Posted October 23, 2018 11 hours ago, hawkeyez88 said: I ended up resetting my controls inside of pinball arcade and things work!!!!! Thanks GAH! Glad you got it sorted out, not clear why your in game controls would have done anything in the first place. Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted October 23, 2018 Share Posted October 23, 2018 4 hours ago, GAH1068 said: Glad you got it sorted out, not clear why your in game controls would have done anything in the first place. It was like my select/enter button would never do anything when FCM & PBA started. As soon as I reset and only changed my flippers, it worked flawlessly, even in full screen mode. 1 Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 23, 2018 Author Share Posted October 23, 2018 Interesting, I guess that would make sense since FCM is sending an enter key at startup to get to the menus. If it somehow got mapped that would at least explain why. Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted October 23, 2018 Share Posted October 23, 2018 Thanks again for all of your help on this! Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted October 24, 2018 Share Posted October 24, 2018 And just like that --- 1.71.17 cabinet is out. Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 24, 2018 Author Share Posted October 24, 2018 And now we wait for next FCM build so things work again. Ordered a kinect 2.0 USB adapter to try out it with arcooda build Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 24, 2018 Author Share Posted October 24, 2018 NoEx replied to my post already, said new build should be up in a few hours. Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted October 24, 2018 Share Posted October 24, 2018 15 hours ago, GAH1068 said: NoEx replied to my post already, said new build should be up in a few hours. Man he's quick! I'll be putting the new version on tonight and testing, as I'm sure you will be too. I ordered the Kinect too, should have it before the weekend, I'm extremely interested in this! Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 24, 2018 Author Share Posted October 24, 2018 I installed over lunch. Tested a few tables and looks good. Now I can play with Kinect tonight. UPS will deliver the adapter sometime later this afternoon 1 Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted October 24, 2018 Share Posted October 24, 2018 19 hours ago, GAH1068 said: And now we wait for next FCM build so things work again. Ordered a kinect 2.0 USB adapter to try out it with arcooda build The Kinect with TPA is pretty awesome. The search for the usb connector was not easy, but ordered it end of June. I hope that one day VPX will also support kinect 2.0 Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted October 24, 2018 Share Posted October 24, 2018 Does anyone have the full pbx database.xml file with all the cabinet tables in it? And would like to share ? Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 24, 2018 Author Share Posted October 24, 2018 Here is my Arcooda database file with all the tables. Arcooda.xml 1 Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 24, 2018 Author Share Posted October 24, 2018 I messed around with the Kinect feature. It is cool, but to me, more of a novelty. Not sure if I will play a ton with it on. Going to give it a few more days and see how I feel about it. 1 Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted October 24, 2018 Share Posted October 24, 2018 GAH - to get your standard PBA tables to launch are you using the built in system area in pinballx? Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 25, 2018 Author Share Posted October 25, 2018 No, I use custom one for that as well. Ok - I take back the Kinect is a novelty feature. The more I play the more I am liking it. Once you start getting use to the movement it is pretty cool. 1 Quote Link to comment Share on other sites More sharing options...
BrandonLaw Posted October 25, 2018 Share Posted October 25, 2018 9 hours ago, GAH1068 said: No, I use custom one for that as well. Ok - I take back the Kinect is a novelty feature. The more I play the more I am liking it. Once you start getting use to the movement it is pretty cool. I've always been curious of this...off to youtube I go to see what this is all about. Quote Link to comment Share on other sites More sharing options...
BrandonLaw Posted October 25, 2018 Share Posted October 25, 2018 This to me looks unbelievably disproportionate. It looks like the fish tales' lock ramp is 15" away from the playfield. Is this what you see when you play? Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted October 25, 2018 Share Posted October 25, 2018 You mean with the kinect ? No just shows you yhe normall playfield, it only moves the camera a bit when you move your head, so it looks like you can look arround the object. I made some videos a couple of months ago in my test env. Not sure how I can share them Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted October 25, 2018 Author Share Posted October 25, 2018 I haven't tried all the tables using Kinect. I played Funhouse and Whitewater for about an hour or so (use to own both tables about 15 years ago so they are still among my favorites) and then tried out TAF, Circus Voltaire, TZ and Dracula. I must not have calibrated the kinect right the first time because the tables felt disproportionate as @BrandonLaw said. If I moved too much it really through things off kilter. After calibrating again things are much better and head movements don't cause such dramatic changes. Quote Link to comment Share on other sites More sharing options...
BrandonLaw Posted October 25, 2018 Share Posted October 25, 2018 @GAH1068 That makes more sense. The vid I checked out this morning on youtube may have just been a 'general' view uncalibrated for the user and looks ridiculous to the masses Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted October 25, 2018 Share Posted October 25, 2018 15 hours ago, GAH1068 said: No, I use custom one for that as well. Ok - I take back the Kinect is a novelty feature. The more I play the more I am liking it. Once you start getting use to the movement it is pretty cool. Thanks Gah - I created another script too and was playing with it last night. Thanks again for your guidance. 1 Quote Link to comment Share on other sites More sharing options...
DrEvil Posted November 15, 2018 Share Posted November 15, 2018 Hi I am making progress but stuck here: I have obtained .17 version of Arcooda and the latest version of FCM However, the .17 version of acrooda does not run, I think because I do not own a KINECT. Is there a version of FCM fro Arcooda version .14? Quote Link to comment Share on other sites More sharing options...
