Stern tables appear to be much quieter in PBX than all other tables.  I have verified the volumes are fine for the rom/dmd itself and audio is set to 100% in PBX Settings as well.  If I play table in Visual Pinball the audio is much better.  I do not recall this being an issue in the past but maybe an update caused this?  Metallica and AC/DC to mname a few
Anyone else?
Does the usual END key, followed by the 8/9 keyboard buttons not do the trick?
You may also need to do the F3 / Reset before setting the levels with END+8/9.
