no table audio and audio launch sounds
Hello, I use Pinball X recently with v3.28. I have a problem with the table audio and audio launch files. I have put the files in the Table Audio and Audio Launch folder, with the same name as the table, but I get no sound in the Frontend. If I start pinx without data in the folder (Table Audio and AudioLaunch), i hear the startup music. If I have data in the folder, the sartup music breaks off and I hear nothing more. Has anyone a idea? Thx for help.
Would you mind attaching copies of your pinballx.ini and log.txt files in reply to your thread? Thanks.
