Hello,
I'm trying to finish to configure Pinball Arcade, I'm able to launch a table from PinballX using TPAFreeCamMod. While I'm at PinballX selecting the table I see the backglass on the second monitor. But when I launch it the table opens fine but the backglass is gone, any ideas? I'm using PinballX 3.20 and the lastest Pinball Arcade & TPAFreeCamMod.
Is TPA with Freecam mode launching fine without PinballX?
Did you setup the correct launching file in Settings for Freecammod ?
Are table for VPX launching fine ?
Is all is ok, please post your log and pbx ini file
