Did you originally have the 32-bit version and force install the 64-bit version over it. If so, download again and install 32-bit. Otherwise, reinstall over the top as normal for your build.
I think its an issue creating the backglass form. Probably because Flash is not installed or the wrong architecture version is installed. Try deleting c:\pinballx\flash.ocx (this might be a pain) then reinstall.
