1.    Give a brief description of you sytem setup (2/3 screen setup, feedback, addressable leds)
I have two screen setup.  main screen is portait, the 2nd one is landscape. basic homemade pinball cab.  I'm using mouse controls for flippers and an xbox controller for plunger and nudge.  Homemade pinball cab.
2.    Are you using any 3rd party add-ons (dmdext, doflinx, PUplayer)
the only 3rd party ones I know of are xmouse and xpadder.
3.    Define which emulator you are having issues with (VPX, Future Pinball, FX3)
I am using Future Pinball on PBX.  I can run FX3 fine, but it supports the controller already.
4.    Is the issue table specific or an issue for all tables? If so please state the table name.
All Future Pinball tables don't provide for the joysticks on the xbox controller to be mapped for plunder and nudge (like I do in FX3).  I have tried to use xpadder to map the keyboard functions to the xbox controller.  it seems to work (testing in notepad), but when I'm playing any FP game there is no response from the joysticks.
5.    Does this issue occur only when launching the game via PBX?
Seems to be the same issue if I try to run it in Future Pinball itself.  Once I started using PBX, I don't go back to using FP.
6.    What Version of PBX are you on?
version 3.04
7.    Attach your Pinball X xml, ini, and log files, DO NOT COPY THE CONTENTS INTO YOUR QUESTION, attach the actual files.
PinballX.ini
SetupWizard_en.xml
[SETTINGS].log
Hi,
As far as I know Future Pinball uses RawInput so I don't think XPadder works with it. Im also pretty sure windows 10 creators update broke some of Xpadder with certain emulators/programs.
You may well be out of luck here. Sorry.
Cheers.
Tom.
Could try Joy2Key. Only one that comes to mind that hasn't been broken by Windows 10.
