[RESOLVED] installed3.17..stuck on registering files
so I'm just now installing new 3.17 and looks like last step registering files just seems to loop?  I can go to game mgr and lauch a game fine , but will not start from pinball shortcut on desktop?
*so I had to task mgr out of this, but seems to be working on start up now..idk, I did have to go back and reinstall without checking dmd2 support, all is good now and seems faster load times, I never did read the change log between 3.16 and 3.17, ? Was wondering what improvements there was?
18:21:20.0  8/29/2018:  PinballX - Version 3.17 x64
18:21:20.0  8/29/2018:  Windows 10 Pro 64-bit (8GB)
18:21:20.0  8/29/2018:  Loading Settings
18:21:20.1  8/29/2018:  Initialize Component
18:21:20.1  8/29/2018:  Initialize Display
18:21:20.1  8/29/2018:  Loading PlugIns
18:21:20.1  8/29/2018:  Loaded Plugin:"DirectOutput PinballX Plugin" Version 1 By Swisslizard
18:21:20.2  8/29/2018:  PlugIn Did not initialize. Disabling PlugIn
18:21:20.4  8/29/2018:  Created DirectX BackGlass Window
18:21:20.4  8/29/2018:  Looking for startup images
18:21:21.5  8/29/2018:  Testing Flash engine.
18:21:21.5  8/29/2018:  Hiding Cursor
18:21:21.6  8/29/2018:  Hiding Taskbar
18:21:21.6  8/29/2018:  Getting GPU Information
18:21:21.6  8/29/2018:  CPU:  Intel(R) Core(TM) i5-7600 CPU @ 3.50GHz
18:21:21.6  8/29/2018:  GPU 1: NVIDIA GeForce GTX 1080
18:21:21.6  8/29/2018:  Displays: 2
18:21:21.6  8/29/2018:  Load Game List
18:21:21.6  8/29/2018:  Loading Database: Visual Pinball
18:21:21.6  8/29/2018:  Loading Database: Visual Pinball PM5
18:21:21.6  8/29/2018:  Loading Database: Visual Pinball X
18:21:21.7  8/29/2018:  Loading Database: Visual Pinball 9.2
18:21:21.7  8/29/2018:  Loading Custom Database: Favorites
18:21:21.7  8/29/2018:  Initial load gamelist took: 78ms
18:21:21.7  8/29/2018:  Finding and matching artwork and videos
18:21:22.1  8/29/2018:  Took: 406ms
18:21:22.1  8/29/2018:  Loading Game Statistics and Scores
Have you tried rebooting your PC and downloading and installing PinballX again?
  • Draco1962 changed the title to [RESOLVED] installed3.17..stuck on registering files
  • Draco1962 locked this topic
