[RESOLVED] Pinball x freezes at load after updating from 3.07 to 3.11
HI , I have just updated from 3.07 to 3.11 and pinball x freezes at load screen. Previous upgrade , i had to delete the flash.ocx file. Did the same for this , but still locks up.
Windows 7 system
Please post your log file so I can try and troubleshoot the issue.
Wheel images are also recreated with this release if you chose to show company of system logos on top of them. This may cause a long delay on first run. Please let it run. If that is not the issue please post your log.
Thanks.
Tom.
Thanks Tom , yeah that sorted it out. That initial load time was several minutes. Appreciate the suggestion.  Thanks and keep up the great work.
In the future, will it be possible to create lists via manufacturer and/or year ?
