I was, up until today successfully capturing backglass and dmd videos with no problem using pinballx.  But as of today for some reason I am able to capture backglass mp4's just fine but my dmd videos all end up zero bytes in size (obviously with no video).  I have verified my dmd size and position settings in pinballx and any dmd video's previously recorded play just fine in the proper position.  I imagine this is being caused by something stupidly simple but I will be darned if I can find it so far.
Any suggestions?
Gwen
Sorry, I meant to include the fact that I am getting the following in the pinballx log:
22:58:30.8  7/29/2018:  Error capturing DMD video
22:58:30.8  7/29/2018:  Exit System Control Pressed
Can anyone suggest what might be causing this?
I am running windows 10 64 bit, I have the ffmpeg.exe properly installed (obviously since the backglasses are recording ok).
Gwen
I still haven't been able to solve this problem.  I have had to switch to using pbx recorder  to record the dmds.
You may want to attach full copies of your pinballx.ini and log.txt files from when the error occurred. I do not use this feature so I won't be able to help but there are others that might be able to help you sort it out with more information.
