I just upgraded to Pinball X 64bit 3.01 and latest codecs.  I'm on Windows 7 64bit.  While everything works great, minus the occasional slow table video load, i'm not hearing the flipper sounds or the launch button sound.  Any help would be appreciated.  Thanks
PinballX.ini
A few things you will want to look at.
- Double check your audio settings and driver.
- Does it work if you reinstall and force it to 32-bit?
Thanks for the reply.  It works on the 32bit, but I want to stay on the 64bit of course.  :)   Audio settings look good, everything works audio wise, minus the flipper sounds and launch button.  I'm going to screw around with the Lav audio settings.
I was wondering why there was a new topic exactly the same then I see the other one was locked and marked as resolved. It really didn't seem to be resolved though just that it didn't affect all and I cant duplicate it. Probably my bad.
Hi Tom, if there is something you would like me to test out, just let me know.  I'm determined to get the 64-bit version to work on my PC.
