im marking favorites from different systems and some dont show on the list. looks like the ones not showing are from my vp systems, where i use lists instead of a long xml. im attaching my DBs.
where are the favorites stored? could not find that  to troubleshoot.
Databases.zip
5 hours ago, Draco1962 said:
Attach your pinballx.ini and log.txt files whenever reporting an error.
no error, just functionality gap. The DBs should provide you with all the info you need.
Moreover, it seems like the "All" list only reads from [system_name]\[system_name].xml (which in my case for VP, vp9 and vp9pm5 is blank) and not from [system_name]\[group].xml (visual pinball\dmd.xml for example). Same goes for Last Played and Most played.
to work around this I had to create a "Complete collection" group/list and include all the individual xmls it. This does not solve the favorites issue though.
Would it be possible for theseautomatic lists toread through all XMLs, like groups do? If not, you’d always have to add/modify/delete table entries in 2 XMLs, at least.
Ok. Though users should probably be made aware that the new lists do not work with old groups and that Table entries have to be duplicated for everything to work. It will be confusing to many otherwise. Thanks.
