So i decided to do a nice fresh install of GameEx and for some reason the volume isnt working correctly.
If I use my Xbone controller or Keyboard neither will turn the volume up in GameEx. When i press the volume up key it will always revert back to zero.
The GameEx Volume icon is always on the right side of the screen as well.
Ive attached a screenshot of what it looks like
Any Ideas?
Probably going to need you to attach your gameex.ini and log.txt files, Ray.
Will do when i return from the school run.
Ive checked the log and gameex.ini and I cant see anything out of the ordinary but I will upload regardless.
Sorry forgot to mention that the directional keys dont work either, so i cant navigate menus. Ill upload ini's shortly.
Does it happen when you only have either the Xbox One controller or the keyboard/mouse installed? Have you modified your Input Settings? I am not able to replicate your issue, especially the volume going back down to 0 by itself. As for the volume indicator, it has always appeared on the right side of the screen.
When I did the fresh GamEx install I didnt change any input settings.
The issue seems to have resolved by itself, not sure how. If it does pop up again ill let you know.
Any recent Windows updates? Have seen some transient oddness occur around them.
Not sure I have done any windows updates in a while. I did an update for Geforce Experience but im not sure if that would have caused the issue I had.
