Pike13 Posted April 14, 2018 Share Posted April 14, 2018 Not sure if this is a bug or feature so apologies if I missed the change log that stated this was on purpose...but are the instructions that you can display not suppose to take up the whole (backglass) screen anymore? Seems sometime after 2.65 when I attempt to show the instructions it only shows in the top/left backglass screen. Perhaps 1/6 of the screen. Usually this is okay as you can still make out the instructions but they previously filled up the whole screen. And for some of the instructions I have, specifically the animated instruction cards that were put together for Pinball FX2 (here) , that amount of space isn't enough to show the detail. I'm using PinballX 2.75 in a three screen cabinet. Noticed the problem in both normal launching and one click launching mode. If it is a feature, anyway to turn it off? As an aside, is there an official change log that shows the changes between versions? I can't seem to find one and the download page usually doesn't have anything listed. Am I totally missing something or looking in the wrong place? PinballX.ini log.txt Link to comment Share on other sites More sharing options...
jimmay3 Posted April 16, 2018 Share Posted April 16, 2018 I have the same issue, started with the rollback versions (2.74 & 2.75)... Link to comment Share on other sites More sharing options...
Pike13 Posted April 18, 2018 Author Share Posted April 18, 2018 Thanks for verifying that I'm not the only one seeing it. I still wonder though...bug or feature? Inquiring minds want to know. Link to comment Share on other sites More sharing options...
jimmay3 Posted April 18, 2018 Share Posted April 18, 2018 Could be, but some tables have full screen and others small in upper left corner, I'm wondering if there is 2 diff based on file type. I have some in png and some in swf, so have to check. Link to comment Share on other sites More sharing options...
jimmay3 Posted April 19, 2018 Share Posted April 19, 2018 Yes, this issue seems to have started a v2.74 and something to do with file type. All .swf files appear to shrink to top left corner of BG and .png stay full screen like the past... Example attached, my Blank Knight is Small, but Black Knight 200 is large... Link to comment Share on other sites More sharing options...
jimmay3 Posted April 19, 2018 Share Posted April 19, 2018 Incase the prior is unreadable... Yes, this issue seems to have started a v2.74 and something to do with file type. All .swf files appear to shrink to top left corner of BG and .png stay full screen like the past... Link to comment Share on other sites More sharing options...
Tom Speirs Posted April 21, 2018 Share Posted April 21, 2018 Hi, its resolved in the latest version. Cheers. Link to comment Share on other sites More sharing options...
Pike13 Posted April 21, 2018 Author Share Posted April 21, 2018 Confirmed, it works. Thanks for the quick fix. Link to comment Share on other sites More sharing options...
PootisSpencer Posted April 24, 2018 Share Posted April 24, 2018 Sorry but this still hasn't worked for me. Its still shrinking the instruction cards that are .swf format Link to comment Share on other sites More sharing options...
Draco1962 Posted April 24, 2018 Share Posted April 24, 2018 8 minutes ago, PootisSpencer said: Sorry but this still hasn't worked for me. Its still shrinking the instruction cards that are .swf format Attach copies of your pinballx.ini and log.txt files. Link to comment Share on other sites More sharing options...
PootisSpencer Posted April 24, 2018 Share Posted April 24, 2018 I don't have many .swf instruction cards as most of mine are .png but even with the .png cards its shrinking them. log.txt PinballX.ini Link to comment Share on other sites More sharing options...
jimmay3 Posted April 24, 2018 Share Posted April 24, 2018 v2.82 was good for me, will have to test v2.83... Link to comment Share on other sites More sharing options...
jimmay3 Posted April 25, 2018 Share Posted April 25, 2018 Just installed latest v2.83, no issues with istructions shriking anymore. v2.83 is solid for me, especially with new menu additions... Link to comment Share on other sites More sharing options...
