I'm so close here, I finished up my cabinet this past friday and got everything up and running to near perfection. The one thing I can't figure out, is how to get gameex to let my monitor turn off at the minimum and better yet to let my computer go to sleep when not in use. After searching I only found 1 solution and the setting change doesn't appear in gameex arcade.  Anybody know how to get this working? Would be nice to not have to manually turn things on or off.
There is no setting in GameEx that will do this. You may need to look at your Windows Power Management settings to adjust the idle settings to either sleep or shutdown after a set amount of time.
