Hi is there a reason why when i start a table it goes to fx3 pinball table then after 4 seconds it disapears back to select table in pinballx but can still hear the table prevously selected still running in background have to use taskmanager to exit pinballx then i can see table running still.
you need to post you ini and log, and xml files to get help.
I'm guessing your cabinet setting isnt configured in fx3 and you have the incorrect parameters set for fx3 in your settings.
Are you running doflinx or dmdext addons?
Hi found problem because I had it stored in d drive the shortcut icon on desktop wasn't showing proper icon for pinball fx3 so reloaded it to c now all ok must have had a corrupt link somewhere but thanks for reply.
