coda514 Posted February 27, 2018 Share Posted February 27, 2018 Hi, after reading the thread about ePSXe I was able to get that running (finally). However I cant quite get Nulldc running properly. It lists the games, but when I select a game I just launches Nulldc, but not the actual game. Ideally, it would just launch the game without me seeing the Nulldc interface, but at this point if it would just launch the game that would be great. I have included my config file for your viewing pleasure. Nulldc.txt Link to comment Share on other sites More sharing options...
simbamame Posted February 27, 2018 Share Posted February 27, 2018 this might help. 1 Link to comment Share on other sites More sharing options...
RedDog Posted February 27, 2018 Share Posted February 27, 2018 Yup, check out snarl's post. I am using the same command line and she is workin'. Link to comment Share on other sites More sharing options...
coda514 Posted February 27, 2018 Author Share Posted February 27, 2018 Thanks guys! After a couple weeks of struggling with this, the simple change to the Nulldc config file solved it. This is an awesome community indeed! I believe this is resolved. Unfortunately, I dont know how to label it as such. Thanks again. Link to comment Share on other sites More sharing options...
RedDog Posted February 27, 2018 Share Posted February 27, 2018 Hi Coda, you can edit any post by clicking the 'Edit' command in the post. I put 'Resolved' in your title for you. Link to comment Share on other sites More sharing options...
coda514 Posted February 27, 2018 Author Share Posted February 27, 2018 Thank you kind sir. Link to comment Share on other sites More sharing options...
simbamame Posted February 28, 2018 Share Posted February 28, 2018 22 hours ago, coda514 said: Thanks guys! After a couple weeks of struggling with this, the simple change to the Nulldc config file solved it. This is an awesome community indeed! I believe this is resolved. Unfortunately, I dont know how to label it as such. Thanks again. @coda514please click the heart on the post that solved it please as it gives us feed back to what helped. Thanks. Link to comment Share on other sites More sharing options...
