Hi I have added VPX to ‘ other systems’ and some tables are working. However there are several tables that do not work through Pinballx. They work fine  outside of the front end. Some of them show line errors in the script and some just get stuck on the loading screen. Any ideas?
I moved your thread to the correct forum (from GameEx to PinballX) so you would get visibility to your issue. You may want to start by attaching copies of your pinballx.ini and log.txt files.
Next, please give more details as your description is rather lacking. Can you identify the tables that are not working and examples of the script errors you are noting?
Hi thanks for the prompt reply. I have sorted it now by relocating the table files into a separate folder away from the other tables.
Cheers
