Trey Andrews Posted December 30, 2017 Share Posted December 30, 2017 I have been using GameEx AE with all of my arcade builds and all of the sudden when I buy 5 AMD Processor PCs it doesn't work. Am I missing something? How can GameEx not work just with a difference in processor. Please Help!! I have many orders I need to fill building these PCs for my friends. Thanks! Here is the last part of the log. 11:25:14.89 12/30/2017: MAME list update took 2 minutes, 20 seconds. 11:25:14.90 12/30/2017: Attract Mode Re-Enabled 11:25:15.35 12/30/2017: 21 Consecutive Exceptions Occured 11:25:15.37 12/30/2017: Object reference not set to an instance of an object. 11:25:15.43 12/30/2017: at Direct2D.Direct2d.Device.TestCooperativeLevel() 11:25:15.44 12/30/2017: at GameEx.GameEx.MainForm.de() 11:25:15.45 12/30/2017: Trying reinitialising the display after sleeping for 4 seconds 11:25:15.46 12/30/2017: Exception count will be dropped to 15 Link to comment Share on other sites More sharing options...
Draco1962 Posted December 30, 2017 Share Posted December 30, 2017 We will need for you to attach complete copies (no copy & paste) of your gameex.ini and log.txt files for review. It might help us to know more specifics about your PC builds - CPU, GPU, etc. Link to comment Share on other sites More sharing options...
Trey Andrews Posted December 30, 2017 Author Share Posted December 30, 2017 ShowLog.exe Link to comment Share on other sites More sharing options...
Trey Andrews Posted December 30, 2017 Author Share Posted December 30, 2017 Thanks for the reply!! Link to comment Share on other sites More sharing options...
Draco1962 Posted December 30, 2017 Share Posted December 30, 2017 2 minutes ago, Trey Andrews said: ShowLog.exe Not sure that this is the gameex.ini and log.txt files I requested. Please click the GameEx How to ask for help link for instructions on where to locate these files if you do not know where to find them. Link to comment Share on other sites More sharing options...
Trey Andrews Posted December 30, 2017 Author Share Posted December 30, 2017 Here they are. GameEx.ini log.txt Link to comment Share on other sites More sharing options...
Draco1962 Posted December 30, 2017 Share Posted December 30, 2017 First, not seeing the error you initially reported so this is not the same log file so far as I can tell. Second, it is generally not recommended to install and run MAME from c:\Users\ path (higher protection by Windows) and generally best from c:\ itself. Looks like you are running MAME Plus! which I am not certain is an official authorized build by MAME Dev. Link to comment Share on other sites More sharing options...
Trey Andrews Posted December 30, 2017 Author Share Posted December 30, 2017 Yes I saw that re downloading it instead of moving the download file over could help. So the first one is from that. We re downloaded and it worked!! But, when we set the media paths to the correct place it crashed (the most recent logs I sent you). Now we are setting paths to things one by one (snaps then logos ect.). When we added videos it crashes. We narrowed it down to that. The videos don't play when we try to play them through the pc's media players. So Maybe its just the transfer of original content being downloaded through intel hardware then trying to use the same content through AMD hardware. Your thoughts? Link to comment Share on other sites More sharing options...
RedDog Posted December 31, 2017 Share Posted December 31, 2017 Video problems are often a result of missing codecs. You might try the LAV filters hosted by GameEx if you haven't thus far. Link to comment Share on other sites More sharing options...
Draco1962 Posted December 31, 2017 Share Posted December 31, 2017 5 hours ago, Trey Andrews said: So Maybe its just the transfer of original content being downloaded through intel hardware then trying to use the same content through AMD hardware. Your thoughts? If you are talking about using a default drive image from an Intel rig and cloning to an AMD rig, then you could have some driver issues, but not likely that is what you are suggesting. Content (videos, still images, ROMs, etc.) are going to be generally OS and hardware neutral, so shouldn't be an issue here. Definitely load the LAV codecs as @RedDog has suggested and report back. Link to comment Share on other sites More sharing options...
