GoPenguins Posted December 24, 2017 Share Posted December 24, 2017 Has anyone noticed any missing roms. For example tempest does not show up in my list. When I launch the game with mame alone it works fine, but doesn't show up in GameEx. I have also downloaded the MAME 0185 rom set from archive and am using that. Link to comment Share on other sites More sharing options...
Draco1962 Posted December 24, 2017 Share Posted December 24, 2017 Can you please attach copies of your gameex.ini and log.txt files in reply to this thread for us to review? I have an idea or two what may be happening but we need these files to avoid second guessing. Thanks! Link to comment Share on other sites More sharing options...
GoPenguins Posted December 24, 2017 Author Share Posted December 24, 2017 GameEx.ini log.txt Link to comment Share on other sites More sharing options...
Draco1962 Posted December 24, 2017 Share Posted December 24, 2017 My guess is that you have Game Filter enabled. You will need to load the Setup Wizard after you identify the ROM names of the missing games and add them in to your Advanced MAME section under Dont Filter these ROMS separated by a semi-colon ; . As an alternative, you can add them manually to the following line in your gameex.ini file as follows: DoNotFilterROMS=aburner;pacman;redbaron;redbarona;splatter;qbert;qbertqub;jungleby;jungleh;junglehbr;junglek; junglekas;junglekj2 This is, of course, from my setup. For yours, you will probably add tempest1r;tempest2;tempest3 depending on the ROM names you have in your collection. Let me know if this helps. Link to comment Share on other sites More sharing options...
GoPenguins Posted December 25, 2017 Author Share Posted December 25, 2017 That of course worked. Not sure why I should have to do that, but thank you very much for your assistance. Link to comment Share on other sites More sharing options...
Adultery Posted December 25, 2017 Share Posted December 25, 2017 You don't have to do that if you disable the filtering, as Draco mentioned. Link to comment Share on other sites More sharing options...
dschulpius Posted December 26, 2017 Share Posted December 26, 2017 I have 0185 romset (Split) and also using Mame 0.185. I can confirm that any of the revisions of Tempest will not show up in GameEx. I noted this when I updated to .185 because it's one of my faves and couldn't find it. Adding the rom names to the Dont Filter these ROMS line does make them reappear but like GoPenguins. I'm wondering why I'd have to do this? Link to comment Share on other sites More sharing options...
Draco1962 Posted December 26, 2017 Share Posted December 26, 2017 As was noted by me and @Adultery, if you enable filtering, there will be some ROMs that get caught up in the process if ther filtering. Could be imperfect or some other flag in the dat file for the ROM. So your choices are disable filtering, or occasionally put some ROM names in the Don't Filter section as instructed. This is going to happen and this option is here for that purpose. 1 Link to comment Share on other sites More sharing options...
