  • 5 years later...
hi,
when i start any game, it runs too fast... ive already set the clocking speed to 50% but when i enter a big room or something it starts lagging... when i set it back to 100% the big room runs smoothly but the small ones run too fast...
Hi there - you are lacking quite a bit of detail so I will ask some questions:
  • First, what do you mean by running in a big room or small room? Are you meaning to say fullscreen (big room) or windowed (small room)?
  • Second, does this behavior appear the same regardless of whether you are running directly via RetroArch or through the GameEx Evolution frontend?
  • Third, what core are you using within Retroarch? Mupen64Plus or Parallel 64?
  • Fourth, you noted any game. Can you give a few examples of games you tried that had the same results?
Just so you are aware, I do not run GameEx Evolution or RetroArch, but trying to ask what seems to me to be some logical questions that may need to be answered before attempting to steer you in a correct direction.
