Hi,
I have two issues:
First, since the latest update my favorites list that I created as group is listed twice. When I select this list, every table is not two times on the wheel. In game manager I also notice in the system list that all the list are listed twice in the dropdown box.
Second issue:  when I start a table from pinballx, the exit key is only working when I have started a game on the table. When I load the table, and immediately press the EXIT key it does not work. PinballX does not intercept that key then. Is this normal behaviour?
2 things - First, please create a separate thread for your Exit issue. This will make assisting you much easier on an issue-by-issue basis. Provide as much detail as possible (i.e., type of controller you are using for inputs, etc.).
Second, please attach copies of your pinballx.ini and log.txt files within each thread when reporting an issue.
Hi,
The exit issue is okay now. Sometimes I have to press the exit key 2 times but I can live with that.
For the double-tables I have attached the requested files. It happened after the update. I see all tables two times on the wheels, also on the "all tables wheel"...
pinballx.ini
vp10 favorites.xml
