cesar quijada Posted November 30, 2017 Share Posted November 30, 2017 trying to clean up the start menu on GameEx Arcade Edition I want to remove the options last played, random game, original games, vector games, not played, etc etc etc. from the start menu and only leave steam and mame options visible in the start menu. the question is the same as in the link: https://www.gameex.info/forums/topic/19018-gameex-arcade-edition-custom-menus/ in the link look at a method and try to do it but I did not understand -I do not know which is the default theme folder to which its content has to be copied -about modifying theme = default I wonder if it is what is written as theme = Default - Default inside the GameEx.ini file -I also dont know where the file theme.ini is located since I do not know which is default theme folder -in the image I show the mentioned files and folders, this image is from the topic of the link described above mind Link to comment Share on other sites More sharing options...
Tom Speirs Posted November 30, 2017 Share Posted November 30, 2017 Hi, Its not currently possible to change the start menu with arcade edition other than enabling/disabling items in the setup wizard. What you are looking applies to regular GameEx. Link to comment Share on other sites More sharing options...
cesar quijada Posted December 1, 2017 Author Share Posted December 1, 2017 thanks for the answer tom Link to comment Share on other sites More sharing options...
Tom Speirs Posted December 1, 2017 Share Posted December 1, 2017 No worries. A custom menu editor for registered users would be a nice touch though in the future. Link to comment Share on other sites More sharing options...
Draco1962 Posted December 1, 2017 Share Posted December 1, 2017 On 11/29/2017 at 8:27 PM, cesar quijada said: Yestrying to clean up the start menu on GameEx Arcade Edition I want to remove the options last played, random game, original games, vector games, not played, etc etc etc. from the start menu and only leave steam and mame options visible in the start menu. the question is the same as in the link: https://www.gameex.info/forums/topic/19018-gameex-arcade-edition-custom-menus/ in the link look at a method and try to do it but I did not understand -I do not know which is the default theme folder to which its content has to be copied You answered it in your second bullet below -about modifying theme = default I wonder if it is what is written as theme = Default - Default inside the GameEx.ini file Yes! -I also dont know where the file theme.ini is located since I do not know which is default theme folder Look under GameEx Arcade\Themes 4 It just takes a little poking around to find and discern what was meant as my original response was never intended to be an in-depth guide since there are limitations to skinning the GameEx Arcade version. Link to comment Share on other sites More sharing options...
cesar quijada Posted December 2, 2017 Author Share Posted December 2, 2017 thanks for the answers for now I will do the same with the standard version :) Link to comment Share on other sites More sharing options...
