Slashbot Posted November 9, 2017 Share Posted November 9, 2017 Anyone can help me solve this problem,i cannot find it myself? since i activated the Direct output PinballX plugin now PinballX stopped working when exit user interface. Everything is working fine leds,tables,..., it only when exiting back to windows got this message; error: pinballx has stopped working a probleml caused the program to stop working correctly please close the program logfiles are attached Grts from Belgium log.txt DirectOutputpbx.log Link to comment Share on other sites More sharing options...
rablack97 Posted November 10, 2017 Share Posted November 10, 2017 whats in that stopx script? Link to comment Share on other sites More sharing options...
Slashbot Posted November 10, 2017 Author Share Posted November 10, 2017 Stopx : my ledblinky script But i already disabed it, problem not solved #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. ; #Warn ; Enable warnings to assist with detecting common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% process = FutureDMD.exe Loop { prev := ErrorLevel Process, Close, %process% Process, Exist, %process% } until !ErrorLevel or (prev = ErrorLevel) Run, C:\Program Files\LEDBlinky\LEDBlinky.exe off Sleep, 500 Run, taskkill /IM LEDBlinky.exe 0,,UseErrorLevel ExitApp It only happens when i enable the Direct output PinballX plugin Link to comment Share on other sites More sharing options...
rablack97 Posted November 10, 2017 Share Posted November 10, 2017 is this your first time installing DOF? can you run a table with DOF outside of PBX with no issues at exit of the table. whats in here? C:\Pinballx\scripts\Start PinballX.exe Link to comment Share on other sites More sharing options...
Draco1962 Posted November 11, 2017 Share Posted November 11, 2017 @Slashbot did you get this fixed? Saw your pincab video with LEDs blinking away. Link to comment Share on other sites More sharing options...
rablack97 Posted November 11, 2017 Share Posted November 11, 2017 The leds worked, he was just getting the error on exiting pbx. @Slashbot make sure you check and see if you have any other programs running in the background that you trully dont need. I used to get errors but it was due to a program i had running in the background once i removed the errror went away. Link to comment Share on other sites More sharing options...
