Is there a way to get Pinball x to launch fruit machine using MFME?
I am using the setup wizard, others systems and think the problem has to do with the parameters line.   I have tried a a bunch of things, [TABLEPATH], /play -"[TABLEPATH]\[TABLEFILE]", and many other ones but get an error not a value integer value.  The extension for the fruit machine is .gam.
any help??
You may want to attach your mfme.xml, pinballx.ini and log.txt files for others to review.
xml
<?xml version="1.0"?>
-<menu>
-<game name="Addams Family DX 5 quid Multi Stake">
<description>Addams Family DX 5 quid Multi Stake</description>
<rom/>
<manufacturer/>
<year/>
<type/>
<hidedmd>True</hidedmd>
<hidetopper>True</hidetopper>
<hidebackglass>True</hidebackglass>
<enabled>True</enabled>
<rating>-1</rating>
</game>
</menu>
log
19:30:34.7  10/22/2017:  PinballX - Version 2.38
19:30:34.8  10/22/2017:  Windows 7 Home Premium Service Pack 1 64-bit (7.9GB)
19:30:34.8  10/22/2017:  Loading Settings
19:30:34.8  10/22/2017:  Initialize Component
19:30:34.8  10/22/2017:  Initialize Display
19:30:35.9  10/22/2017:  Loading PlugIns
19:30:36.0  10/22/2017:  Created DirectX BackGlass Window
19:30:36.1  10/22/2017:  Hiding Cursor
19:30:36.1  10/22/2017:  Hiding Taskbar
19:30:36.1  10/22/2017:  CPU:  AMD FX-8370 Eight-Core Processor
19:30:36.1  10/22/2017:  GPU 1: NVIDIA GeForce GTX 1060 6GB
19:30:36.1  10/22/2017:  Displays: 2
19:30:36.1  10/22/2017:  Load Game List
19:30:36.1  10/22/2017:  Loading Database: slots
19:30:36.2  10/22/2017:  Finding and matching artwork and videos
19:30:36.2  10/22/2017:  Loading Game Statistics and Scores
19:30:37.3  10/22/2017:  Loading Surfaces
19:30:37.5  10/22/2017:  Finished Loading Surfaces
19:30:37.5  10/22/2017:  Initialize Audio
19:30:37.5  10/22/2017:  Set Keyboard Controls
19:30:37.5  10/22/2017:  Initialize Joystick
19:30:37.6  10/22/2017:  Auto configure Visual Pinball
19:30:37.6  10/22/2017:  No Joysticks Attached
19:30:37.6  10/22/2017:  Started
19:30:41.0  10/22/2017:  Launch System
19:30:41.0  10/22/2017:  Waiting for threads
19:30:41.0  10/22/2017:  Disposing display
19:30:42.8  10/22/2017:  E:\Users\main frame\Documents\slots\mfme v5.1\MFME v5.1 (Win7)\MFME.exe /play -"E:\Users\main frame\Documents\slots\mfme v5.1\MFME v5.1 (Win7)\Games\Addams Family DX 5 quid Multi Stake"
19:30:51.3  10/22/2017:  Exit System Control Pressed
19:30:53.9  10/22/2017:  Created DirectX BackGlass Window
19:30:56.8  10/22/2017:  Exiting
19:30:57.1  10/22/2017:  Showing Taskbar
19:30:57.1  10/22/2017:  Unhiding Mouse Cursor
19:30:57.1  10/22/2017:  Disposing Plugins
19:30:57.1  10/22/2017:  Saving Settings
19:30:57.1  10/22/2017:  Bye
pinballx
WaitFor=20
[Internal]
lastwheelcachematchsize=-1123
lastselected=Addams Family DX 5 quid Multi StakeAddams Family DX 5 quid Multi StakeSystem_2
filter_year=
filter_company=
filter_custom=
filtername=Tables
[PinballArcade]
Executable=steam.exe
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff1414
[System_3]
Enabled=False
WorkingPath=C:\Visual Pinball
Executable=VPinballx.exe
NAME=Visual Pinball X
SystemType=1
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=15
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowState=2
WindowSize=650,478
WindowLocation=401,301
[Topper]
monitor=2
[System_2]
Name=slots
SystemType=0
WorkingPath=E:\Users\main frame\Documents\slots\mfme v5.1\MFME v5.1 (Win7)
TablePath=E:\Users\main frame\Documents\slots\mfme v5.1\MFME v5.1 (Win7)\Games
Executable=MFME.exe
Please attach the files in your reply. It is hard to read on a smart phone when you have to scroll a long copy and paste. Also we will often download the files for testing.
You might not get an answer right away as this may not have many users attempting what you are with this type system.
Try this:
[System_2]
Name=slots
SystemType=0
Executable=MFME.exe
Parameters=/play -"[TABLEFILE]"
Alternatively since I am not sure if the /play - is necessary or not
Parameters="[TABLEFILE]"
Have you seen this thread?
There might be some clues for a proper command line.
