Hello guys
I have a small probleme with media dmd video
I deed When i start pinballx my backglass and my dmd video are play  on the display 2. All it's ok
I run a table pinballfx3. ... i play. ... and when i quit pinballfx3. ....the dmd video is under the backglass .... somebody has the same problem ? Or a solution please
My codec is LAV
I give you file log later in the day
Thank
You have small text as well! :P
Be sure to attach a copy of your pinballx.ini as well. Thanks!
hello
Ok i have found solution and alone :P:P:P !!!
In gamedata all table : I disable "hide dmdvideo"
Pinballfx3 show dmd.... and when i close pinball fx3 ... dmd video in pinballx play alway !!
