Hi Tom....
I recently had to do a reinstall of my MCE machine. All up and fine with Game Ex back on there. The only problem I have is I can not seem to get my nag screen to remove (though I have registered and have unlocked it before)
Was there something skipped in versions perhaps?? Or did you change the Donation process to encourage new/repeat donations????
Or is my machine scrwed again!!!
Did you add a language support in the regional settings in windows?
I have the same problem, in that if i choose a regional settings of Chinese, i'll get the nag screen, and if i reset it back to US English, the nag is gone.
Hi Tom....
just run the reg file you were sent when you registered that will remove the nag screen again :D
Yeppers..have to run your reg hack and that will go away!
Have been running my reg hack like a man possed!!!
Also tried changing language but with no success...
Did the location that the reg file writes to change?? I did register a while ago...
I would appreciate any more help with this. I have 3 systems, all having the same problem. One was a rebuild, install GameEx.. run reg hack... Nag Screen Remains. One is Laptop that didnt have GameEx installed... reg hack.. nothing.... One was a unregisterd version... run hack (have checked to make sure not corrupt) and nothing!!!!!
Anyone??
Anyone??
does the reg hack just not work at all or work then stop working, are you loged in as administrator?
Sorry, reg hack works... if I nip in to regedit and take a look the subkey is added etc. So that all seems fine. Have tried on a couple diffrent systems, all of which I am admin of.
Was the registration process changed at all???? I registered about a year ago.. if that matters?
have you done the reg hack on a clean install of your o/s and a clean install of gameex?
if you still have problems your probly best contacting tom, i have not heard of this problem myself
That was how problem first came about... I had Gameex on a MCE machine running fine for over a year. It was attacked by my wife, well she picked up the keyboard and it was never the same.
I did a full reinstall and applied the Reg Hack and nothing!!! Today I installed Game Ex on a diffrent machin and same prob.
Have emailed Tom, though I can only imagine how busy he is so I dived in here 2!!!!! Any one got any suggestions am happy to try!!!
You should probably edit the registry and manually check if the reg key has been added. Also clear your temp files and cache just to be on the safe side.
if he's done it on a fresh install it cant be the problem
Tom helped me out by supplying a new reg key. Which worked first time.
Am guessing the process was changed at some point, thanks for the help though guys.
Maybe worthwhile checking this thread if you need to do a full rebuild!!!
